Per our previous discussion: PSOC6: CY8C6247BZI-D54 Pin out
-->The decision was made to use the PSOC 6 MCU CY8C624ABZI-D44 Instead of the CY8C6247BZI-D44. Thank you for your help in helping me persuade my customer to take that huge improvement now instead of later.
Overview:
I received the CY8CPROTO-062-4343W PSoC 6 Wi-Fi BT PROTOTYPING KIT. This kit contains a CY8C624ABZI-S2D44ES2 1943 B 33 CYP 636440 W3A633
1. Is this the latest chip with latest firmware?
Development:
2. I am not able to load the CY8CPROTO-062-4343W kit with wiced IDE, having read forums its my understanding that only modustoolbox may be used. Is that correct?
3. From reading the forums it appears that mbed is preferred and recommended for AWS IoT. Is that correct?
4. If 3. is correct, Then does Cypress recommend and provide a cypress-mbed like they do a cypress-freertos?
5. If available, which cypress provided mbed-application(s) is recommended to use as a base for my AWS IOT development? I need mqtt, tls, tcpip, and stuff I dont know I need 😕
William,
The firmware for the CY8C624ABZI-S2D44ES2 is loaded by you. Therefore, the latest firmware drivers are available on the Cypress site. All other application code used for firmware is created by you.
That is my understanding also.
I'm not an expert about that. I believe both ARM's mBed and Amazon's FreeRTOS are real-time OSs available for this platform.
Cypress would have to weight in on that.
Here are some forum sites that might be helpful.
Software Forums
PSoC Creator & Designer Software
Len
