CY8C6245 Softreset code example
paddyliu
Distributor - Macnica(GC)
5 comments on blog First comment on blog First like received
Hi Sir,
We use MTB IDE,   is there any code example about  CY8C6245 Softreset ? thanks.
Paddy
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @paddyliu ,
You can use the API " NVIC_SystemReset() " to perform a software reset on the PSoC 6 device.
Warm Regards
Alen
AlenAn14
Hi @paddyliu ,
Warm Regards
Alen
paddyliu
Hi Alen,
Got it with thanks.  I check the API " NVIC_SystemReset() " in PDL or HAL  documentation, but I can't find any information about NVIC_SystemReset(). Can you recommend some documentation for these API.Thanks.
Regards.
Paddy
AlenAn14
Hi @paddyliu ,
The API I mentioned above is an API from the CMSIS library for Cortex - M MCU's like PSoC.
The Documentation for this API can be obtained here.
Warm Regards
Alen
