NiBu_4687336
5 solutions authored 50 replies posted 25 replies posted
Hi.
I just updated to the latest libraries, and ModusToolbox 2.4, and ran into problems. I tracked them down to the fact that compile_commands.json no longer includes "-DCOMPONENT_CAT1" as part of the compiler command line. It used to define both COMPONENT_CAT1 and COMPONENT_CAT1A, but now only defines COMPONENT_CAT1A.
This breaks, among other things, _cyhal_utils_get_clock_count(), which now returns a value of 1 for all clock types.
I've worked around the problem by adding "CAT1" to the definition of COMPONENTS in my Makefile, but clearly that's not how it's supposed to work.
What happened? Did I do something wrong, or fail to follow some update procedure, or is this an oversight by Cypress developers?
-Nick
NiBu_4687336
Hi @AlenAn14.
The problem was resolved by updating the BSP. Apparently, libraries aren't really backward compatible.
-Nick
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @NiBu_4687336 ,
Can you please let me know the device/evaluation board which you are using to test your firmware ?
Warm Regards
Alen
NiBu_4687336
Hi @AlenAn14.
-Nick
Hi @NiBu_4687336 ,
Glad your issue is resolved and thank you for sharing the solution with the community!
The major version changes in the libraries are not backward compatible, like v1.x.x to 2.x.x.
Warm Regards
Alen
