CM4 debug not working
podericof
First reply posted First like given First question asked
Hi there,
I'm using PSoC Creator 4.4 with PDL 3.1.1.
When I try to debug the CM4 I have the following error:
The start request failed. Encountered error (The processor failed to enter the debug state. Ensure that the selected processor is enabled.)
Do you have any idea? Somebody else has a similar issue, and it was solved by using the latest version of PDL, but in my case it doesn't seems to be working.
Francesco
Gautami_12
50 likes received 100 solutions authored 250 replies posted
Hi @podericof ,
Please check in the systems tab if Debug selects has  SWD+SWV selected.
If not please set it. If it is set to GPIO you may face this issue.
Warm Regards,
Gautami J
Gautami_12
Hi @podericof ,
Warm Regards,
Gautami J
podericof
Thank you! this has solved the problem!
