Build failure after integrating AnyCloud_OTA_Using_HTTPS with AnyCloud_MQTT_Client
BiM_4640481
Level 4
Level 4
25 replies posted 25 sign-ins 10 replies posted
I am working on OTA integration to the main application project and with this I am facing build errors.
In the existing workspace we have Bootloader project, OTA HTTPS project and AnyCloud_MQTT_Client/Main application project, please note that all the standalone projects are working fine.
When we try to integrate OTA code to the AnyCloud_MQTT_Client/Main application project, for that we copied the OTA source files to the source folder and config files to the configs folder of the AnyCloud_MQTT_Client project and also modified the Makefile.
After these changes when we try to build the project, we are facing the following errors.
13:10:39 ** Incremental Build of configuration Debug for project AnyCloud_MQTT_Client **
"C:\\Users\\USER\\ModusToolbox\\tools_2.3\\modus-shell\\bin\\make" CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.2 CY_IDE_TOOLS_DIR=C:/Users/USER/ModusToolbox/tools_2.3 -j4 all
Tools Directory: C:/Users/USER/ModusToolbox/tools_2.3
CY8CKIT-062S2-43012.mk: ./libs/TARGET_CY8CKIT-062S2-43012/CY8CKIT-062S2-43012.mk
C:/Users/USER/ModusToolbox/tools_2.3/make/startex.mk:380: * Build support for the target device not found. Run "make getlibs" to ensure all required build and code dependencies are present..  Stop.
"C:/Users/USER/ModusToolbox/tools_2.3/modus-shell/bin/make CY_MAKE_IDE=eclipse CY_MAKE_IDE_VERSION=2.2 CY_IDE_TOOLS_DIR=C:/Users/USER/ModusToolbox/tools_2.3 -j4 all" terminated with exit code 2. Build might be incomplete.
13:10:41 Build Failed. 1 errors, 0 warnings. (took 2s.468ms)
​Please find attached the modified makefile and request you to help us to resolve the issue.
Binsy M S
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
The discussion will be continued in the other thread which was created.
https://community.cypress.com/t5/PSoC-6-MCU/Build-error-while-integrating-AnyCloud-OTA-Using-HTTPS-w...
Alakananda
