- Email to a Friend
I am getting a build error when I try to measure the temperature using thermistor. It's saying
prjM0120:Build error: undefined reference to Thermistor _GetTemperature'
Can anyone help?
- Email to a Friend
Hi @aliissa02,
I hope you have included the Thermistor.c and Thermistor.h files into your PSoC6 project. Please make sure you follow the instructions from 7:42 to 9:10 present in the video.
I have attached the project which I've recreated at my end for your reference.
Nikhil
- Email to a Friend
Hi @aliissa02,
Are you using Thermistor Calculator component? The function you are using is int16 Thermistor_GetTemperature (uint32 resT).
After configuring the component, make sure you have built the project. This will generate the Thermistor.c and Thermistor.h files containing all the APIs. After this step, the APIs will be recognized in your application code. Also, I see a space in the API call displayed in the error log "Thermistor<space>_GetTemperature". Remove the space and try to build again, the project must positively build without any errors.
Nikhil
- Email to a Friend
Thanks for your response. I have basically followed this video https://youtu.be/lME10oZX8b4 but not sure why it's giving this error.
prj.M0120:Build error undefined reference to Thermistor GetTemperature
It keeps saying this
- Email to a Friend
- Email to a Friend
Hi @aliissa02,
Nikhil
- Email to a Friend
It's working. Thanks alot!
