- Email to a Friend
Hello.
Build for attached project becomes fail.
PSoC Creator version is 4.4.
Can infineon CDC team make build this project?
What is the solution to this build error?
Best Regards.
YuMa
PSoC 6 MCU
- Email to a Friend
Please check the attached project I am not facing any issues with this project and I hope you are using latest version of the PSoC Creator.
Thanks & Regards
Pratiksha V
- Email to a Friend
In PSoC Creator go to Tools -> Options and set the latest PDL Path as shown in the snapshot below and check.
Please let me know if this helps
Thanks & Regards
Pratiksha V
- Email to a Friend
Hi Pratiksha-san.
Thank you for your response.
The latest PDL version I have is 3.1.3.
Build will fail in this version.
Can this project be built only with 3.1.5?
If so, please send PDL 3.1.5 version.
Best Regards.
YuMa
- Email to a Friend
You can also work with the PDL version you have that is 3.1.3.But it will be good if you go for latest version you can download it from below link.
Thanks & Regards
Pratiksha V
- Email to a Friend
- Email to a Friend
I am not facing this type of issue can you create your project folder on your desktop folder and check once.
Thanks & Regards
Pratiksha V
- Email to a Friend
- Email to a Friend
Thanks & Regards
Pratiksha V
- Email to a Friend
Hi Pratiksha-san.
The ZIP file you attached contained three files:
No1. PSoC6ABLE II MTK+TWI+RT-Lib (Uncompressed project)
No2. PSoC6ABLE II MTK+TWI+RT-Lib.7z (Compressed project)
No3. Regulatory Test Firmware Manual.docx
2 projects were included.
No1 project(Uncompressed project) build is completed successfully.
But No2 project(Compressed project) failed to build like the first project I attached.
Q1)
The build results are different for 2 projects.
What is the difference between these 2 projects?
Why only No2 project fails to build?
Q2)
Did you build both No2 project and the project I attached first in your environment?
Best Regards.
YuMa
- Email to a Friend
Q1) There is no difference between two projects I just unzipped your shared project and checked for build issues.
Q2) I tested your shared project in my environment initially it was facing PDL path issues and solution for that is shared before.
Thanks & Regards
Pratiksha V
- Email to a Friend
Hi Pratiksha-san.
Thank you for your support.
I understand.
Best Regards.
YuMa
