I am trying to create the bootloader build in example, but its giving me this error.
ERROR:Failed to export the "MCUboot_based_Basic_Bootloader_for_PSoC_61" application to Eclipse IDE for ModusToolbox™.
- MCu_Bootloader
Hi @Manoj_Kumar ,
Please check if have you done the second point
If not please add the python installation path from the ModusToolBox installation directory to the top of the system path environmental variables. Then try to import the project.
We tried this method and this project is working properly at our end.
Warm Regards,
Gautami J
Hi @Manoj_Kumar ,
Please check if you have added the correct location in the tools path. By default, it should be located in ~/ModusToolbox/tools_3.0, where ~ is your user home directory.
If this does not solve the issue. Can you please send the screenshot of the error logs?
Also please refer to a similar thread.
Warm Regards,
Gautami J
Hi @Manoj_Kumar ,
We tried to import/create the MCUboot_based_Basic_Bootloader code example via the project creator by selecting CY8CKIT-062-WIFI-BT as the desired board. It got created without any problem.
Can you please try using a different workspace directory and try creating your project there?
Also please let us know which device you are using.
Warm Regards,
Gautami J
Am using an CY8CKIT-062S2-43012. Now its getting created, but when i build the application that is the bootloader application its giving me these errors.
make[4]: *** No rule to make target '../../mtb_shared/mcuboot/v1.8.1-cypress/boot/cypress/platforms/security_counter/cy_security_cnt.c', needed by 'C:/Users/Developer/mtw/MCUboot_based_Basic_Bootloader_for_PSoC_61/bootloader/build/APP_CY8CKIT-062S2-43012/Debug/ext/mtb_shared/mcuboot/v1.8.1-cypress/boot/cypress/platforms/security_counter/cy_security_cnt.o'. Stop.
make[4]: *** Waiting for unfinished jobs....
make[3]: *** [../../mtb_shared/core-make/release-v3.0.2/make/core/main.mk:376: secondstage_build] Error 2
make[2]: *** [C:/Users/Developer/ModusToolbox/tools_3.0/make/application.mk:72: build] Error 2
make[1]: *** [../../mtb_shared/core-make/release-v3.0.2/make/core/build.mk:314: build_application_bootstrap] Error 2
make: *** [../../mtb_shared/core-make/release-v3.0.2/make/core/main.mk:376: secondstage_build] Error 2
Hi @Manoj_Kumar ,
Warm Regards,
Gautami J
