We started a project with the CY8C6137BZI-F34 Psoc6. We started from the mtb-example-psoc6-emwin-oled example project provided with Modustoolbox. We changed some configuration in the make file such the device in the CY8CKIT-062-WIFI-BT.mk.
We also generated a new configuration with the device configurator with the matching microcontroller.
However, we always catch Cy_SysLib_ProcessingFault() when we execute the line 2236 in the cy_syspm.c of the psoc6pdl. See the screenshot below.
I'm a bit confuse because this section on the code is only applicable ""if curDevice == CY_SYSLIB_DEVICE_PSOC6ABLE2"". My device is not PSoC6 BLE2 device Family ID right? I feel we miss something to reconfigure for running the project on the CY8C6137BZI-F34.
Hello PaSt_4467756,
The error might be because the Target device might not have been changed in all the dependent files.
Can you please create a custom BSP by following the steps mentioned in this thread and see if that resolves your issue?
Thread link - 61xx family in Modus Toolbox?
Hope this helps,
Thanks and Regards,
Rakshith M B
Rakshith M B
Hello PaSt_4467756,
Hope this helps,
Thanks and Regards,
Rakshith M B
Rakshith M B
