fjb
CY8CPROTO-062, -62S3, and -063 are marked as prototyping boards for PSOC 6. Looking into the BOM lists attached, all kits are listing CY8C5868LTI-LP039, which is a PSOC 5 family member.  Are the BOM incorrect?
What  MCU kits can I order to get a PSOC 6 chip?
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear Franz-san,
The CY8CMOD-062-4343W and 062S3-4343W  seems to come with  a 2MB flash device CY8C624ABZI-S2D44. Is this correct?
According to the schematic of cy8cmod-062-4343w_schematics The PSoC 6 on board is CY8C6247BZI-S2D44.
According to the schematic of cy8cmod-06s3-4343w the PSoC 6 on board is CY8C6245LQI-S3D72.
CY8CPROTO-063-BLE comes with CYBLE-416045-02 (1MB Flash)
https://www.cypress.com/documentation/datasheets/cyble-416045-02-ez-ble-creator-module
Based on this, the CY8CPROTO-062 prototyping kits seem to fit best for Cortex-M4 code debugging. Or am I missing something?
If you need 2MB flash,  among these three (CY8CPROTO-062-4343W, CY8CPROTO-063-BLE, CY8CPROTO-062S3-4343W), CY8CPROTO-062-4343W seems to be the only option.
Meantime, there is CY8CKIT-064B0S2-4343W which also has CYB0644ABZI-S2D44 (1856KB Flash))
Please refer to the Kits page for the whole list of EVBs.
https://www.cypress.com/microcontrollers-mcus-kits#psoc6
13-Aug-2021
Motoo Tanaka
MotooTanaka
Level 9
Level 9
I think that the 5LP MCU (CY8C5868LTI-LP039?) is used to realize the KitProg,
which is the on board debugger/programmer.
And those kits also have a PSoC 6 (Module) on board, too.
CY8CPROTO-062-4343W: CY8CMOD-062-4343W
CY8CPROTO-062S3-4343W: Carrier_Module
CY8CPROTO-063-BLE: CYBLE-416045-02
If you want to get a PSoC 6 (not a module) on an EVB
CY8CKIT-062-BLE: CY8C6347BZI-BLD53
CY8CKIT-062-WiFi-BT: CY8C6247BZI-D54
and etc..
moto
(Edited)
fjb
OK, understood, PSOC 5 is used as interface device.
I tried to identify MPN of the PSOC 6 mounted on each of these boards, but so far not successful.
Can you help here as well?
MotooTanaka
Level 9
Level 9
After posting my first response, I edited the response to include the part number.
Could you try to re-load the page and check if you can see the MCU names?
moto
fjb
Hi Moto,
Dear Moto,
Thanks for your hint, I indeed missed your 2nd edit.
Looking into the kits and their PSOC 6, I noticed that these are 1MB flash devices.
I couldn't identify the PSOC 6 used in the CY8CPROTO-063-BLE module. From the memory configuration it seems to be  a CY8C6347 derivative. Can you confirm this?
BR
Franz
MotooTanaka
Level 9
Level 9
Dear Franz-san,
13-Aug-2021
Motoo Tanaka
