Hello
I am using PSOC 6 and I want to establish a BLE connection and send data to mobile device. Please note that I have my own mobile app and wont be using cysmart. I have attached my project. I have already used
https://github.com/Infineon/mtb-example-psoc6-ble-throughput-freertos
but it didnt work. Can you please help?
Hello @aliissa02 ,
The project which you are referring from the Github is MTB based project. For PSoC Creator, you can refer to the code examples (CE222046_GATT_OUT, CE215119_BLE_Battery_level) from the PSoC Creator. Please note that C++ is not supported by PSoC Creator.
P Yugandhar.
Your example only works with psoc 4 and not 6.
Thank you
Hello @aliissa02 ,
Please refer to the attached GATT_OUT code example from the PSoC Creator. You can check this code example with your application. In the mobile app, when you click on the 'Notify' then it will send the data to the mobile.
P Yugandhar.
Hello @aliissa02 ,
Please download and install the latest PDL (3.1.5) from this link.
P Yugandhar.
Thanks for your reply. I am still having the same problem. It is still not working. All other projects that I have are working except this one.
Hello @aliissa02,
In your PSoC Creator project, go to Project > Build Settings > Peripheral Driver Library. Make sure the PDL path exists based on the version you installed.
P Yugandhar.
Thank you very much for this. It is working now and I was able to program the psoc device. However, I am not able to see the device when I scan BLE devices around me on the mobile phone. Also, how can I send data to the mobile phone?
Thank you
Hello @aliissa02 ,
Once you program the device, then it will advertise with GATT_Out name and address as shown below.
If you didn't see the device advertising in your mobile app then please check with any of the BLE Apps like LightBlue once.
After you connect the device with your app, then click on the 'Notify' to receive data in the mobile.
P Yugandhar.
Thanks for your reply. I still cant see it when I scan BLE. I have tried different phones and apps but cant find it.
Hello @aliissa02 ,
Are you using the Infineon Dev board or custom board? If you are using the custom board, then please share your schematic files.
Please open the Tera-term and check whether you are able to see the Advertising print or not as shown below.
P Yugandhar.
Hello @aliissa02,
From your schematic files, i didn't see the WCO Crystal used.
In the code example, by default WCO will be enabled as LFCLK source for low power application, so you can either change to PILO clock (for LFCLK) and check or disable the BLE Low-power mode in the BLE component and check your application.
Please note that it is not recommended to use the PILO clock for the BLE low power application. It is recommended to use only WCO for the low power application. For more information, please refer to the BLE component datasheet and BLE_PDL documentation (Right click on the BLE Component to find the datasheets).
P Yugandhar.
Okay, thank you for this. But what is a WCO crystal? can you please provide more information about it? and do you think that I shoukd redesign my board?
Thank you
Hello @aliissa02 ,
Watch Crystal Oscillator (WCO) is an external high accurate 32.768-kHz clock source. It is the primary clock source for the RTC. The WCO can also be used as a source for CLK_LF. If you want the BLE low power operation, then WCO must be selected as the LFCLK source for proper BLE timings during low power mode. If you want to use the PILO instead of WCO, then they are some limitations, which you can refer from the BLE PDL documentation.
P Yugandhar.
Hello @aliissa02 ,
Schematic looks good. How are you connecting the VBACKUP in the schematic? VDD and VBACKUP may be shorted together externally. They are not required to be separate input voltages. Please refer to the page 18 in the CYBLE-416045-02 datasheet.
For reference, you can refer to the CY8CPROTO-063-BLE PSoC 6 BLE Prototyping Kit schematic files.
P Yugandhar.
Regarding the VBACKUP, this pin is connected directly to the battery terminal (nominally 3.7 V), bypassing all the power management circuity. I did this to ensure that VBACKUP is always suppled, even when the device is turned off.
Thank you
