Hi community,
I need your help on something. For information I use mtb2.4 and bless lib and ble is configured in peripheral mode.
How we can allow gatt connexion only for paired/bonded devices ?
Another question, If multiple devices are paired and connect to the system what is the way to recognize if one device was previously conected to the system ?
Thank you for your support,
Kind regards,
Hello @PSOC6_dev ,
We would recommend using MTB 3.0 with new AIROC BT Stack. If you want to use the old BLESS Stack, then you can use the PSoC Creator.
Q1) How we can allow gatt connexion only for paired/bonded devices?
Ans: After devices are bonded, they do not have to go through the pairing process again when reconnected.
You can add the paired/bonded devices to the whitelist data, and in the Filter Policy(in BLE Component) set to Connect request: whitelist. This will allow Connect Requests only from White List devices.
Q2) Another question, if multiple devices are paired and connect to the system what is the way to recognize if one device was previously connected to the system?
Ans: You can use the function Cy_BLE_GAP_GetBondList() which returns the count of bonded devices and the list of bonded devices with their BD address and bdHandle.
P Yugandhar.
Hi @Yugandhar ,
Sorry for my late answer,
Thank you for your feedback!
Q1 -> Yes, i do this. But on a "fresh" device i need to add an extra step.
I want to allow connection and read/write char only for paired/bonded devices.
When pairing is done i activate white list and all is fine but I don't know how to do at the very first connection.
Do you have any idea ?
Anyone has the same use than mine ?
Hello @PSOC6_dev ,
During first connection, once the device is paired and bonded then you can add the device to whitelist using Cy_BLE_AddDeviceToWhiteList() API.
P Yugandhar.
Hi @Yugandhar
Thank you for your feedback.
I'm already doing this. My problem is when my device is in "pairing mode" it accept connection from all ble central devices that connect to it.
If the ble central just connect and do not try to pair after it use one "connection slot" for nothing and block connection for others ble central devices (I set max conn to 1).
I have an issue on windows because after I unpair the device on Windows one process continuously connect to the unpaired device and do not let some other devices to pair...
Hello @PSOC6_dev ,
Once the device is paired/bonded then after disconnection, in the code, you can set the Advertiement filter policy to Scan request: Any | Connect request: White List (which Process scan requests from all devices and connect requests only from devices in the White List).
During second connection, this will allow connection from only whitelist devices.
cy_ble_discoveryModeInfo[CY_BLE_PERIPHERAL_CONFIGURATION_0_INDEX].advParam->advFilterPolicy = CY_BLE_GAPP_SCAN_ANY_CONN_WHITELIST;
Cy_BLE_GAPP_StartAdvertisement(CY_BLE_ADVERTISING_FAST, CY_BLE_PERIPHERAL_CONFIGURATION_0_INDEX);
Please let me know if I'm missing something.
P Yugandhar.
