I am in the process of creating an application that will use the Automation IO GATT Service with an Analog Characteristic.
In the process of writing my code it threw up a warning on the expected data type for the analog parameter in the Send Notification function.
uint16_t myAnalogValue;
apiResult = Cy_BLE_AIOSS_SendNotification(appConnHandle, CY_BLE_AIOS_ANALOG, CY_BLE_AIOS_ANALOG, sizeof(myAnalogValue), &myAnalogValue);
When I look at "Cy_BLE_AIOSS_SendNotification" function, I see that the value parameter is defined as uint8_t, while the default for an analog value is uint16_t.
So, before I trawl through the generated source library code, to fathom my method to handle this, I simply wondered (weathers cold and brain like a battery) what's the recommended way to remove the warning.
Now that brain has warmed up I'm thinking a little clearer.
The solution is relatively straightforward
#define INSTANCE_ANALOG (0u)
uint8_t myByteArray[2];
myByteArray[0] = (myAnalogValue & 0xFF);
myByteArray[1] = (myAnalogValue >> 8);
apiResult = Cy_BLE_AIOSS_SendNotification(appConnHandle, CY_BLE_AIOS_ANALOG, INSTANCE_ANALOG, sizeof(myByteArray), (uint8 *)&myByteArray );
Now surely, this opens up the ability to send uint8_t array sizes of any length, which goes against the Automation IO Service analog value requirement of only using a uint16_t type for value with an exponent to show size.
Hence I am suggesting that the API changes to only allowing uint16_t values and the size option is removed as a parameter.
