Asking the RX Not Empty Interrupt.
GlJe_1688511
Level 4
Level 4
Distributor
100 sign-ins 10 likes given 50 questions asked
Hello.
I attached the Rx Not Empty Interrupt.
When there isn't 'Int_value = __get_BASEPRI();'
When there isn 'Int_value = __get_BASEPRI();'
'Int_value = __get_BASEPRI();' seems meaningless, why does it make a difference?
is there any Errata on this issue?
Thanks and Best regards.
Glenn.
Alakananda_BG
50 likes received 250 sign-ins 250 replies posted
Hi @GlJe_1688511 ,
We could recreate the same issue at our end when we used 'Int_value = __get_BASEPRI(); in the code.
Can you let us know what is the reason for using 'Int_value = __get_BASEPRI(); in the code is there any specific reason to do so?
Alakananda
GlJe_1688511
Level 4
Level 4
Distributor
Hello Alakananda.
I don't need to use 'Int_value = __get_BASEPRI();'
in code without 'Int_value = __get_BASEPRI(); ',I tested it because looped data was wrong.
When it added code in Interrupt Handler, looped data was wrong.
Glenn.
Alakananda_BG
Hi @GlJe_1688511 ,
The standard method which we use is, inside the UART ISR call the Cy_SCB_UART_Interrupt(UART_HW,&UART_context); interrupt.
Alakananda
GlJe_1688511
Level 4
Level 4
Distributor
Hello Alakananda.
This firmware is infineon's example(CE219656, UART_Low_Level_User_ISR).
I only added the 'Cy_SCB_UART_Put(UART_HW,read_data);'
Are there some problems in the example?
Glenn.
