MSS
5 likes given 50 sign-ins 10 replies posted
I used psoc programmer to burn the hex files on to the poc 4 devices.
Do we have something similar tool for Psoc6 Hex file.
Let me know using JTAG how can I burn the HEX files on to flash.
wisc_ece353
10 replies posted First question asked 10 sign-ins
Infineon does have their set of programming tools for PSoC 6. However, it depends on the tool you used to generate the hex file. If it is PSoC Creator, you will need PSoC Programmer. Note that you will have to export your PSoC Creator project in order to create a JTAG-compatible executable.
If you are using ModusToolbox, then you can use Cypress Programmer.
wisc_ece353
