- Email to a Friend
Hello all,
I am using CY8CKIT-062S4 PSoC 6 kit for development purposes.
In that kit, due to unavailability of the digital input pins, I have to use the Analog pins of the controller. So due to that, I am using P10.5 and P10.6 pins as digital input pins.
I have configured these pins as follows:
.outVal = 0,
.driveMode = CY_GPIO_DM_STRONG,
.hsiom = UserLapSel_HSIOM,
.intEdge = CY_GPIO_INTR_DISABLE,
.intMask = 0UL,
.vtrip = CY_GPIO_VTRIP_CMOS,
.slewRate = CY_GPIO_SLEW_FAST,
.driveSel = CY_GPIO_DRIVE_1_2,
.vregEn = 0UL,
.ibufMode = 0UL,
.vtripSel = 0UL,
.vrefSel = 0UL,
.vohSel = 0UL,
I don't want to enable interrupt, so I have disabled it, after using Cy_GPIO_Pin_Init(GPIO_PRT10, 5U, &UserLapSel_config).
But after initializing the GPIO, when I am reading the state of GPIO, it is not able to sense the 3.3V digital input.
I have read on the forum that I have enabled some other functionalities specifically for this Analog specialized pin using HSIOM, but I am unable to do that. Please suggest to me what things do I need to operate this P10.5 to read as a digital input pin?
Thank you.
Vivek Karna
PSoC 6 MCU
- modustoolbox
- psoc 6
- Email to a Friend
Hi @vivekatamantya ,
I have replicated your issue on my end. Please refer to the code below:
cy_rslt_t result;
/* Initialize the device and board peripherals */
result = cybsp_init() ;
if (result != CY_RSLT_SUCCESS)
CY_ASSERT(0);
__enable_irq();
cy_stc_gpio_pin_config_t GPIO10_5 = {.outVal = 0,
.hsiom = P10_5_GPIO,
.intMask = 0UL,
.driveSel = CY_GPIO_DRIVE_FULL};
Cy_GPIO_Pin_FastInit(P9_0_PORT, P9_0_NUM, CY_GPIO_DM_STRONG, 1, P9_0_GPIO);
Cy_GPIO_Pin_Init(P10_5_PORT, P10_5_NUM, &GPIO10_5);
//Cy_GPIO_Pin_FastInit(P9_0, P9_0, CY_GPIO_DM_STRONG, 1, P9_0_GPIO);
for (;;)
if(Cy_GPIO_Read(P10_5_PORT, P10_5_NUM)){
Cy_GPIO_Write(P9_0_PORT, P9_0_NUM, 1);
}else{
Cy_GPIO_Write(P9_0_PORT, P9_0_NUM, 0);
I have a LED connected to P9_0 to observe whether it works or not. I was able to read P10_5 and toggle P9_0 accordingly. This was done on CY8CKIT-062S2-43012 kit, please replicate the code at your end and let me know the result.
Warm Regards
Sobhit
- Email to a Friend
cy_rslt_t result;
CY_ASSERT(0);
__enable_irq();
.intMask = 0UL,
for (;;)
}else{
Warm Regards
Sobhit
