wenzhu
First like given First solution authored 10 replies posted
root@ORU3668_MAIN:~# tpm2_nvdefine -Q 1024 -C o -s 788 -a "ownerread|policywrite|ownerwrite" > tmp.txt
WARNING:esys:../tpm2-tss-3.0.3/src/tss2-esys/api/Esys_NV_DefineSpace.c:337:Esys_NV_DefineSpace_Finish() Received TPM Error
ERROR:esys:../tpm2-tss-3.0.3/src/tss2-esys/api/Esys_NV_DefineSpace.c:122:Esys_NV_DefineSpace() Esys Finish ErrorCode (0x000009a2)
ERROR: Failed to define NV area at index 0x1000400
ERROR: Esys_NV_DefineSpace(0x9A2) - tpm:session(1):authorization failure without DA implications
ERROR: Failed to create NV index 0x1000400.
ERROR: Unable to run tpm2_nvdefine
wenzhu
Hi @Sneha_P , thanks for your reply. I have found the answer.
Sneha_P
250 sign-ins First comment on blog 50 solutions authored
Hi @wenzhu ,
"authHandle" (parameter a) has to be set to the index handle. Please try the following command:
While defining index:
tpm2_nvdefine 0x1500016 -C o -s 32 -a ownerwrite|authwrite|policywrite|ownerread|authread|read_stclear -P your_owner_authorization -p your_nv_authorization
More info on tpm2_nvdefine: https://github.com/tpm2-software/tpm2-tools/blob/master/man/tpm2_nvdefine.1.md
wenzhu
