After disconnection and then reconnect again, BLE indication cannot be received
Jiabin
Level 4
Level 4
25 replies posted First solution authored 10 likes given
We are using the PSoC 6 with BLE as the peripheral device.
We found the following phenomenon:
After building the connection, when there is a long distance between the center device and the peripheral device, a disconnection happens.
Then, we reconnect to the peripheral device and enable the indication of certain characteristics of the peripheral device, but we could not receive the indication.
Very much appreciate it if anyone can provide any hint about the reason.
Yugandhar
1000 replies posted 5 likes given First comment on blog
Hello @Jiabin ,
Are you using PSoC Creator or MTB IDE for your application ?
At the peripheral side, did you receive the Indication enable write request ? If yes,  did you got any error while sending the indications through API ?
Did you tried write/notify to the device  ?
P Yugandhar.
Yugandhar
Hello @Jiabin ,
P Yugandhar.
