PSoC™ 6
hiroki
New Contributor II
hello, I run DFU using the android Cysmart app,but only occasionally succeeds. Almost stops at the notation "Executing Enter Bootloader Command..."
Which is worse ? Cysmart app or source.
Enviroment
CYBLE-416045-02
PDL3.1.5
Psoc creator 4.4
CE220960
Android OS 12
CySmart ver 1.3.0.139
By the way,it works fine with iOS apps.
hiroki
Yugandhar
Could you please check with some other Android phones ? Also, check with Android OS 11 and 10.
P Yugandhar.
hiroki
New Contributor II
Hi,P Yugandhar
Today,I received some phones.but they are android 9.I can't update to android 10 or 11. so I'm searching how to do update.I'll reply after solution.
Reagerds,
hiroki
hiroki
New Contributor II
Hi,P Yugandhar
Sorry I made you wait.
I ran it using  android 9~12.
Result
OK 9,10
NG 11,12
regards,
hrioki
hiroki
New Contributor II
Hi,P Yugandhar
Thanks for the reply.
Right now, the only other phone I have is Android 9. I tried it, but the result was the same.
But I think I'll be able to try it on 11 by the day after tomorrow, so I'll report back then.
Hiroki
Top labels
