PSoC™ 6 Forum Discussions
Sachin_Patel
10 sign-ins 5 questions asked 5 replies posted
what is AWS Data endpoint  for smaple example of  AWS_OTA_USING_MQTT?
PRI
Moderator 50 sign-ins 25 replies posted 10 solutions authored
The AWS Data Endpoint is the broker address which can be found in the settings of your AWS IoT account. You'll have to copy that address to the "AWS_IOT_ENDPOINT" macro in "credentials_config.h" file.
PRI
Sachin_Patel
Thanks, @PRI  For your kind support.
