I want to use ARM Compiler 6 in Keil but the exported code from PSoC Creator generates many warnings and errors. Are there plans to support this soon?
Yes, I can compile using version 5. I fixed the errors using version 6 and my program seems to run correctly but I need to do more testing. The changes I made are mostly in the ARM pack files exported by PSoC Creator so every time I update the pack I need to overwrite the changed files again.
Are you able to build the exported project using other ARM compiler below version 6
