I am trying to build an application that includes CapSense , BLE, and FreeRTOS using PSoC 6 BLE pioneer kit (CY8CKIT-062-BLE) with an E-Ink display.
I believe that I have included all the libraries needed but still got error message:
GeneratedSource/cycfg_ble.h:38:10: fatal error: cy_ble_event_handler.h: No such file or directory
Below are some sample codes that I've referred to:
- CAPSENSE Buttons and Slider FreeRTOS
- Bluetooth LE Find Me
- emWin E-Ink FreeRTOS
Makefile components list:
COMPONENTS=EMWIN_OSNTS FREERTOS BLESS_HOST BLESS_CONTROLLER
Library Manager screenshot is attached.
ispn:39619:1:0
l1:314:1:0
1: It is recommended that you can add the different function one by one.
2: Please make sure the file "cy_ble_event_handler.h" should be generated.
3: Which MTB version do you use? If it is not the latest V3.0, please download from Infineon Website.
4: Please download the latest Bluetooth_LE_Findme which use the "app_bt_management_callback" instead of "cy_ble_event_handler.h".
5: Please open the library manager and click "update".
I was using v3.0 and didn't notice that there is a later version of findme sample code.
Problem solved by using app_bt_management_callback.
