So am trying to work with FreeRTOS and am facing the errors which are not known to me see if anyone can help me. Thank you
1- ./mtb_shared/clib-support/release-v1.3.0/cy_mutex_pool.h:57:1: error: unknown type name 'cy_mutex_pool_semaphore_t'
2- cy_mutex_pool.h:46:2: error: #error "Unhandled RTOS type"
Hi @Manoj_Kumar,
It looks like the COMPONENTS=FREERTOS in the Makefile of the project is not set. Kindly set it and recompile the sources.
Bhamy Narasimha Shenoy
Hi @Manoj_Kumar ,
Can you please help me understand where are you getting these errors?
Are you referring to a code example and you're getting this error?
Can you please guide which Development environment are you using? PSoC Creator or ModusToolbox 3.0?
Thanks!
Kind Regards
Arpit Srivastav
So am using Modustoolbox 3.0.
and am getting those errors in code.
Hi @Manoj_Kumar,
Hi @Manoj_Kumar,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
