I'm attempting to run the WIFI Scan sample for the CYPRESS CY8CKIT-064B0S2-4343W Microcontroller from the ModusToolBox. We are unable to obtain the list of SSIDs scanned from the downloaded sample.
We have attempted to debug the sample after determining that the command complete is failing. Please look at the log given and give us a solution.
Thank you.
Hi @Swarna :
According to your screenshot, the SDIO communication with WiFi module is abnormal.
Because you're using secure MCU PSoC 64, please check whether the MCU is provisioned with keys and policies before being programmed or not.
Detail information you can refer to the README.md in the CE or attached.
Colin
Hi @Qi_Colin :
Keys, policies, and chip provisioning have all been created. If provisioning is not completed, we won't be able to initialize the BSP.
Thank you.
Hi @Swarna :
If so, I think you could try to check the modifications on BSP or hardware.
If no modification, you can try to do cross test with another EVB if possible.
After provision, there're nothing need to modify on BSP and hardware.
Colin
Hi @Qi_Colin :
See how we put up the jumpers on the board in the first screenshot we shared.
Please have a look at the second snapshot, which shows all the libraries that the wifi scan sample has cloned.
We currently lack another evb to test it.
Would you kindly carry out the recommendation to finish the wifi scan on the EVB?
Thank you.
Unsuitable content
