VSCode Compiler Output is misformatted causing warning and errors to not show up
azBlock1
First solution authored 10 sign-ins 5 sign-ins
I am using Visual Studio Code (VSCode) along with PSOC6 project which was created using Modus Toolbox version 3.0.0.9369.
I originally created a BSP and generated a Visual Studio Code project directly using the Infineon project creator.
The project builds and generates a .hex file successfully and im able to debug it on the MCU.
However, during the build the compiler messages get improperly printed causing the error and warning parser in VSCode to not pick them up correctly.
Screenshot attached shows what the compiler output actually looks like and it appears to print parts of multiple messages interleaved with each other which causes visual studio code to report different amount of warnings/error on each build.
Any help on how to make this work better would be appreciated as this is the only combination of compiler and editor where ive ever had a problem not being able to read the actual compiler messages.
PandaS
250 replies posted 100 solutions authored 5 likes given
Hi @azBlock1 ,
We have created an internal ticket for the same issue. Respective teams are working on it to resolve the issue. Thank you for pointing this out.
Thanks and regards,
Sobhit
PandaS
Hi @azBlock1 ,
I recreated the issue at my end. Thank you for pointing this out. I will create an internal ticket regarding the issue of Compiler Output mis format in VSCode for MTB3.0 project.
Warm regards
Sobhit
haneefdm
First reply posted Welcome!
Did you check the "PROBLEMS" tab? I believe VSCode puts all extracts the errors/warnings from the output (terminal) and puts them in the PROBLEMS tab.
Yes VSCode puts what it can parse out into problems tab. But the problem is because the compiler output is not readable by a human VSCode cant parse it out correctly.
A coworker ended up working on the problem since i posted and he found that the following improves the output handling as it was possibly the color coding of text that was causing issues with Cygwin compiler message buffering.
CFLAGS= -fdiagnostics-color=never -fdiagnostics-urls=never -fdiagnostics-path-format=separate-events
haneefdm
You are correct. In addition to what your colleague suggested, the output can be garbled and it is caused by the parallel make. Apparently, you can use the '--output-sync' option on make to make the output come out in a sane manner
 Terminal Output (GNU make)
I have not tried this myself. Lets see if together (CFLAGS and Make option) makes it any better
haneefdm
Yes, errors do show up in the PROBLEMS tab but there seems to be a problem with the problem matcher as the path names to the files don't seem right. Clicking on the error results in an File not found issue in VSCode.
This worked fine in 2.4 and seems to be issue in 3.0
PandaS
Hi @azBlock1 ,
Thanks and regards,
Sobhit
