Hello Infineon support team.
I'm evaluating WLAN(SoftAP mode) using following environment.
- HW: CY8CKIT-062S2-43012
- SW: ModusToolBox version 2.4
TCP_Server Application
In SoftAp mode, I would like to add a custom info in the beacon IE.
I guess the structure "cy_wcm_custom_ie_info_t" will be useful. But I don't know the way exactly.
<cy_wcm.h>
typedef struct
uint8_t oui[CY_WCM_MAX_IE_LENGTH]; /**< Unique identifier for the IE. */
uint8_t subtype; /**< Sub-type of the IE. */
void *data; /**< Pointer to IE data. */
uint16_t length; /**< IE data length. */
uint16_t ie_packet_mask; /**< Mask of the IE details to be included \ref cy_wcm_ie_mask_t */
} cy_wcm_custom_ie_info_t;
Does Infineon have any sample code that use the "cy_wcm_custom_ie_info_t"?
Tayo
ModusToolbox PSoC 6 SDK
May I know what custom info you want to add?
Aditi
Hello Aditi-san
The assumed info is our product ID and so on.
Tayo
