In the ModusToolbox, it seems the SCB interrupts can only be configured to trigger TCPWM or a GPIO.
Is there a different place to configure the SCB to generate an interrupt that my ISR can service?
This is possible in Creator, but I cannot find how to do it in the ToolBox.
ISR component is not exist in ModusToolBox, you may click the 'Configuration Help' link in SCB configuration list and implement you won isr function by referring the code example provided in "Configuration Interrupt" section. For UART, the content like below:
Thank you.
