PWM Counter: Which interrupt number is it using (PDL)
ricardoquesada
Level 4
Level 4
First solution authored 50 sign-ins 25 replies posted
TL;DR: How to know the Interrupt number that is triggered when Counter triggers a Compare or TC ?
I'm migrating a project from PSoC Creator (Schematic editor) to ModusToolbox (PDL).
In PSoC Creator's Schematic Editor, I can assign an interrupt (ISR) to the Counter object.
And I can get the number of the Interrupt because it gets autogenerated by the fitter (?).
E.g: If I have an ISR object called "ISR_Counter", then a "#define ISR_Counter__INTC_NUMBER xxx" will be generated.
And I want to know the interrupt number when using PDL or HAL API?
e.g:
    // Which NVIC will be triggered ?
    cyhal_timer_register_callback(&led_blink_timer, isr_timer, NULL);
Thanks!
PandaS
250 replies posted 100 solutions authored 5 likes given
Hi @ricardoquesada ,
In case you just want to know the NVIC interrupt number, refer to the device.h file.
For PSoC4 - 149 kit the following holds true:
\file cy8c4147azi_s475.h
*                         Interrupt Number Definition
typedef enum {
  /* ARM Cortex-M0+ Core Interrupt Numbers */
  Reset_IRQn                        = -15,      /*!< -15 Reset Vector, invoked on Power up and warm reset */
  NonMaskableInt_IRQn               = -14,      /*!< -14 Non maskable Interrupt, cannot be stopped or preempted */
  HardFault_IRQn                    = -13,      /*!< -13 Hard Fault, all classes of Fault */
  SVCall_IRQn                       =  -5,      /*!<  -5 System Service Call via SVC instruction */
  PendSV_IRQn                       =  -2,      /*!<  -2 Pendable request for system service */
  SysTick_IRQn                      =  -1,      /*!<  -1 System Tick Timer */
  /* CY8C4147AZI-S475 Peripheral Interrupt Numbers */
  ioss_interrupts_gpio_0_IRQn       =   0,      /*!<   0 [DeepSleep] GPIO P0 */
  ioss_interrupts_gpio_1_IRQn       =   1,      /*!<   1 [DeepSleep] GPIO P1 */
  ioss_interrupts_gpio_2_IRQn       =   2,      /*!<   2 [DeepSleep] GPIO P2 */
  ioss_interrupts_gpio_3_IRQn       =   3,      /*!<   3 [DeepSleep] GPIO P3 */
  ioss_interrupt_gpio_IRQn          =   4,      /*!<   4 [DeepSleep] GPIO All Ports */
  lpcomp_interrupt_IRQn             =   5,      /*!<   5 [DeepSleep] LPCOMP trigger interrupt */
  srss_interrupt_wdt_IRQn           =   6,      /*!<   6 [DeepSleep] WDT */
  scb_0_interrupt_IRQn              =   7,      /*!<   7 [DeepSleep] SCB #0 */
  scb_1_interrupt_IRQn              =   8,      /*!<   8 [DeepSleep] SCB #1 */
  scb_2_interrupt_IRQn              =   9,      /*!<   9 [DeepSleep] SCB #2 */
  scb_3_interrupt_IRQn              =  10,      /*!<  10 [DeepSleep] SCB #3 */
  scb_4_interrupt_IRQn              =  11,      /*!<  11 [DeepSleep] SCB #4 */
  pass_0_interrupt_ctbs_IRQn        =  12,      /*!<  12 [DeepSleep] CTBm Interrupt (all CTBms) */
  wco_interrupt_IRQn                =  13,      /*!<  13 [DeepSleep] WCO WDT Interrupt */
  cpuss_interrupt_dma_IRQn          =  14,      /*!<  14 [Active] DMA Interrupt */
  cpuss_interrupt_spcif_IRQn        =  15,      /*!<  15 [Active] SPCIF interrupt */
  csd_interrupt_IRQn                =  16,      /*!<  16 [Active] CSD #0 (Primarily Capsense) */
  tcpwm_interrupts_0_IRQn           =  17,      /*!<  17 [Active] TCPWM #0, Counter #0 */
  tcpwm_interrupts_1_IRQn           =  18,      /*!<  18 [Active] TCPWM #0, Counter #1 */
  tcpwm_interrupts_2_IRQn           =  19,      /*!<  19 [Active] TCPWM #0, Counter #2 */
  tcpwm_interrupts_3_IRQn           =  20,      /*!<  20 [Active] TCPWM #0, Counter #3 */
  tcpwm_interrupts_4_IRQn           =  21,      /*!<  21 [Active] TCPWM #0, Counter #4 */
  tcpwm_interrupts_5_IRQn           =  22,      /*!<  22 [Active] TCPWM #0, Counter #5 */
  tcpwm_interrupts_6_IRQn           =  23,      /*!<  23 [Active] TCPWM #0, Counter #6 */
  tcpwm_interrupts_7_IRQn           =  24,      /*!<  24 [Active] TCPWM #0, Counter #7 */
  pass_0_interrupt_sar_IRQn         =  25,      /*!<  25 [Active] SAR */
  can_interrupt_can_IRQn            =  26,      /*!<  26 [Active] CAN Interrupt */
  crypto_interrupt_IRQn             =  27,      /*!<  27 [Active] Crypto Interrupt */
  unconnected_IRQn                  = 240       /*!< 240 Unconnected */
} IRQn_Type;
In the ISR you can check the status (compare the counter values) and take action accordingly.
Thanks and regards
Sobhit
PandaS
typedef enum {
} IRQn_Type;
Thanks and regards
Sobhit
ricardoquesada
Level 4
Level 4
Great. So, each counter has a fixed associated interrupt.
Thanks!
