HI
If i already use PSOC6 to generate a 4 channel 16 bit 48K PCM audio data.
i already have modify the USB bNrChannel to 4.
but i can not get 4 channel pcm audio data in the WIN10 software AUDIO Player
so do i veed to modify the USB driver for 4 channels or need to modify other USB DEVICE descriptor
JAMES
James,
Is the device enumerating correctly?
These are the changes you need to do:
1) Enlarge the size of the MaxPacketSize from 294 to 588 in the USB descriptor.
2) In the firmware side, any MACRO that captures the packet size needs to be change.
James,
