PSoC™ 6 SDK
psoc6_beginner
I am using modustoolbox with PSoC6. I am using the latest pdl libraries. I am not getting any warning or error when I am compiling code, but there is some message in IDE showing "ambiguous". Please have a look at the screenshot attached.
Below is the message:
Could you suggest to me what is the problem?
Aashita_Raj
Hi @psoc6_beginner ,
If possible, can you please share the project with us so that we can also check at our end and confirm? Also, can you let us know which ModusToolbox version are you using?
Aashita
psoc6_beginner
Hi Aashita,
I am using:
Eclipse IDE for ModusToolbox
Version: 2.3.0
Eclipse Build ID: 2307
See the ModusToolbox Tools Package build number in your ModusToolbox installation folder, at ModusToolbox/tools_2.3/version-2.3.0.xml.
