Dec 09, 2022
01:48 AM
Dec 09, 2022
01:48 AM
Using new project wizard I created the Empty_SDK project. It is building successfully. But source code indexing is not working. I am not able to view header file contents.
02:19 AM
Dec 09, 2022
02:19 AM
I fixed this issue by making sure mtb_shared project is also open in eclipse workspace. As most of the common header files are referred from this directory.
02:10 AM
Dec 09, 2022
02:10 AM
Hi @pghole :
If the macro definition defined in the Makefile, the related source code can't be viewed by indexing.
In this situation, you should use "Search" function to find it.
Colin
Dec 09, 2022
02:19 AM
Dec 09, 2022
02:19 AM
