- Email to a Friend
Dears,
when debugging project running on CY8CPROTO-062-4343W kit using KitPro3 after few minutes it stop debugging:
Error: kitprog3: get_power command failed
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1015 ms). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1012 ms). Workaround: increase "set remotetimeout" in GDB
Error: CMSIS-DAP command CMD_DISCONNECT failed.
Error: CMSIS-DAP command CMD_CONNECT failed.
Warn : keep_alive() was not invokedError: Error connecting DP: cannot read IDR in the 1000 ms timelimit. GDB alive packet not sent! (3027 ms). Workaround: increase "set remotetimeout" in GDB
When I disconnect and launch debug again, it will only report
Error: CMSIS-DAP command CMD_INFO failed.
If I close ModusToolbox and try to run Cypress Programmer (standalone) it only write:
Info : [CyBridge] Start API initialization
Info : [CyBridge] Hardware initialization complete 1784 ms
Error: [CyBridge] Error = Timeout sending bulk packet
And I must disconnect USB cable to kit (to reset Kitprog3) and start again.
I have only idea that it could be due higher room temperature. I did not do any change in code... only doing debug session set breakpoints and watch variables. Prior to this it works normally for at least 2 days.
Could be something else wrong ?
Best Regards
Radim
- Email to a Friend
Hi Radim:
Ok, I suggest you to do the cross test if this problem occur again.
Best Regard,
Colin
- Email to a Friend
Hi @ravo :
Have you done any cross test with another kit?
According to your log information, it seems that the kiprog3 has some troubles after working few minutes.
Best Regards
Colin
- Email to a Friend
Dear Colin, yes I have another kits, but it look like that it is only on this one. Now today it is working normal.
I get this error when elaborating USB AUDIO demo (as I wrote in another thread, problem with custom launch): https://community.infineon.com/t5/PSoC-6/Unable-to-view-variable-s-value-in-ModusToolbox-Debug-mode/...
Radim
- Email to a Friend
Hi Radim:
Best Regard,
Colin
- Email to a Friend
Dear Coli, thanks for response I think so... maybe it was due "overheating"
I will continue to watch this, and If it will become more starts to fail again I will try another kit.
Regards Radim
