Dears,
when debugging project running on CY8CPROTO-062-4343W kit using KitPro3 after few minutes it stop debugging:
Error: kitprog3: get_power command failed
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1015 ms). Workaround: increase "set remotetimeout" in GDB
Warn : keep_alive() was not invoked in the 1000 ms timelimit. GDB alive packet not sent! (1012 ms). Workaround: increase "set remotetimeout" in GDB
Error: CMSIS-DAP command CMD_DISCONNECT failed.
Error: CMSIS-DAP command CMD_CONNECT failed.
Warn : keep_alive() was not invokedError: Error connecting DP: cannot read IDR in the 1000 ms timelimit. GDB alive packet not sent! (3027 ms). Workaround: increase "set remotetimeout" in GDB
When I disconnect and launch debug again, it will only report
Error: CMSIS-DAP command CMD_INFO failed.
If I close ModusToolbox and try to run Cypress Programmer (standalone) it only write:
Info : [CyBridge] Start API initialization
Info : [CyBridge] Hardware initialization complete 1784 ms
Error: [CyBridge] Error = Timeout sending bulk packet
And I must disconnect USB cable to kit (to reset Kitprog3) and start again.
I have only idea that it could be due higher room temperature. I did not do any change in code... only doing debug session set breakpoints and watch variables. Prior to this it works normally for at least 2 days.
Could be something else wrong ?
Best Regards
Radim
Hi Radim:
Ok, I suggest you to do the cross test if this problem occur again.
Best Regard,
Colin
Hi @ravo :
Have you done any cross test with another kit?
According to your log information, it seems that the kiprog3 has some troubles after working few minutes.
Best Regards
Colin
Dear Colin, yes I have another kits, but it look like that it is only on this one. Now today it is working normal.
I get this error when elaborating USB AUDIO demo (as I wrote in another thread, problem with custom launch): https://community.infineon.com/t5/PSoC-6/Unable-to-view-variable-s-value-in-ModusToolbox-Debug-mode/...
Radim
Hi Radim:
Best Regard,
Colin
Dear Coli, thanks for response I think so... maybe it was due "overheating"
I will continue to watch this, and If it will become more starts to fail again I will try another kit.
Regards Radim
