PSoC™ 6 SDK Forum Discussions
azBlock1
10 sign-ins 5 sign-ins First reply posted
Cant believe im making this post in 2022 but here we are.
Im using Modus Toolbox 3.0.0.9369  on Windows 10 and a project for a PSOC 62 Dual Core MCU.
I went through the project and have created a git repository of a build able project. I have tested this by creating a blank folder, cloning the repo and then switching workspace in Modus Toolbox to this new folder. Then i use Open Projects from File System to import the project into Modus and then i go to Project -> Build All. Here is when i run into an issue.
Successful approach.
Workspace folder has no spaces ex C:\Projects\ActiveProject_workspace\
This works fine and builds as expected.
Failure approach.
Workspace folder has spaces ex C:\Projects\ActiveProject workspace\
This fails to build with the following error:
..."/tools_3.0/make/core_version3/query-v3.mk:68: *** Searching installed tools failed with error code: 1. Stop."
This seems like a bug to me somewhere in the compile process which prevents usage of a workspace that has spaces in the path.
Qi_Colin
250 sign-ins 50 solutions authored 25 likes received
Hi @azBlock1 :
After checked the query-v3.mk below, I think currently we can't support any space in path.
_MTB_TOOLS__MTB_QUERY_ERROR_CODE:=$(shell mkdir -p $(_MTB_START_QUERY_TMP_DIR) && $(_MTB_TOOLS__START_QUERY_CMD) > $(_MTB_START_QUERY_TMP_FILE) ; echo $$?)
ifeq (0,$(_MTB_TOOLS__MTB_QUERY_ERROR_CODE))
$(info Searching installed tools complete)
else
$(error Searching installed tools failed with error code: $(_MTB_TOOLS__MTB_QUERY_ERROR_CODE))
endif
Colin
Qi_Colin
Hi @azBlock1 :
else
endif
Colin
Thank you for replying quickly, while your reply confirms the problem, it seems like a pretty big oversight within the software to be limited to directories without spaces for a software that is brand new in 2022. I hope this gets fixed quickly.
Qi_Colin
Hi @azBlock1:
Thank you for your points.
We will check this issue and try to fix it in the further update.
Colin
