Hi All,
In one of our project we are using the above mentioned psoc. We are using SD card and we are using emfile Filesystem and I am trying to add this library in to the securebliky project using library manager. I am facing the build errors as attached in the log file.
I need help to create this project with emfile Filesystem please suggest me the correct procedure.
Deepak H M
Hi @deepakhm09
Can you please try update the emfile library to the latest version as shown?
And then try building the project again. Please observe whether the error exists.
Thanks and Regards,
Leo
Hi @LeoMathews
Thanks for the quick response I tried the suggestion and still the error is persisted. PFA for the more info.
Deepak H M
Hi @deepakhm09
After adding emfile using the library manager to your project, please edit the makefile as shown.
and
After making the edits in the makefile please rebuild the project.
Thanks and Regards,
Leo
Hi @LeoMathews
As suggested, I tried with Makefile changes, I am seeing different errors. PFA and thanks for the replay.
Deepak H M
Hi @deepakhm09
Looks like the errors arise because the v4.1.0 of the BSP used is updated to use HAL v2.0.0. As it is a major update, it is not backward compatible with code examples that use older versions. To fix the project, user needs to manually update the code to use HAL v2.0.0 API and the list of changes to be done are mentioned are provided here.
Thanks and Regards,
Leo
Hi @LeoMathews
Thanks for the replay. The Issue is on the other hand I am importing emfile middleware to secureblinky application so this secureblinky is already using HAL v2.0.0 I need input on how to upgrade emfile middleware to access these API's.
Deepak H M
Hi @deepakhm09
Can you please look refer to this User Guide and check if it helps?
Thanks and Regards,
Leo
Hi @LeoMathews ,
Thanks for the replay, I was on long leave will check and will come back.
Deepak H M
