Hi! I have added CMSIS library to my psoc 6 project in modus toolbox but there seems to be some missing files. For example: there is a header file: https://github.com/Infineon/cmsis/blob/master/COMPONENT_CMSIS_DSP/Include/dsp/filtering_functions.h
But no corresponding source file for function implementations, should be here or? : https://github.com/Infineon/cmsis/tree/master/COMPONENT_CMSIS_DSP/Source
(compare this to the official CMSIS-DSP git repo that has a folder for FilteringFunctions here: https://github.com/ARM-software/CMSIS-DSP/tree/main/Source )
Dear @jonatan the CMSIS using precompiled libraries in LIB file
if you would like to use you must put LDLIBS to your project makefile, see documentation for CMSIS DSP or this thread https://community.infineon.com/t5/PSoC-6/How-to-use-ARM-CMSIS-DSP-lib-in-ModusToolbox2-4/td-p/342494
modify makefile:
DSP_DIR=../CMSIS/CMSIS/
INCLUDES=$(DSP_DIR)/Include
VFP_SELECT=hardfp
LDLIBS=$(DSP_DIR)/Lib/GCC/libarm_cortexM4lf_math.a
Radim
Radim
modify makefile:
VFP_SELECT=hardfp
Radim
Radim
Ok, thanks!
So the CMSIS that is added as a lib in my modus project isn't enough to be able to use CMSIS-DSP then? Is there a reason why some of the CMSIS-DSP code is included and some not?
