PSoC™ 6 SDK Forum Discussions
shsh_4753781
10 sign-ins 5 sign-ins First reply posted
I am trying to use TFLite library
https://github.com/tensorflow/tflite-micro
to integrate and use ML based application on PSOC6. But since it has main.c and not cpp, it does not allow me to include the files directly. Is there a workaround? I want to use .tflite models with PSOC6 and develop an application using standard TFLite c++ library. Is the issue because of C vs C++?
RodolfoGL
250 sign-ins 5 comments on KBA First comment on KBA
Perhaps you can try to use MbedOS. It is setup to build with C++ and run on PSoC 6.
We do plan to support .tflite models by end of the year (or early next year).
If you can create a Keras-H5 model, instead of .tflite, you can use our current Machine Learning solution for PSoC 6. This is ready to be deployed and its inference engine runs faster than the TFlite library inference engine.
https://www.cypress.com/products/modustoolbox/machine-learning
RodolfoGL
