Hi All,
We are trying to establish connection between the downstream device and IOT edge hub running on a Linux Gateway.
We are using CY8CKIT-064B0S2-4343W as downstream device. As we understand that we can use MQTT protocol to send the data. But the github repo from cypresssemiconducters used to do this is not available.
https://github.com/cypresssemiconductorco/iot-samples/tree/main/connecting-to-azure.
Any other repo is available to complete this task. Help is much appreciated.
PS: We are able to communicate directly from CY8CKIT-064B0S2-4343W to Azure IOTHub using one more repo.
https://github.com/Infineon/mtb-example-azure-iot
Hi @Swarna :
The repo of cypress is not available now, and you can find our code example from https://github.com/Infineon.
For MQTT code example, I think you can refer to https://github.com/Infineon/mtb-example-wifi-mqtt-client.
This is a code example connecting to AWS based on MQTT.
Colin
Hi @Swarna :
Colin
Hi @Qi_Colin ,
We are currently using cy8ckit-064b0s2-4343w evaluation board. The repo https://github.com/Infineon/mtb-example-wifi-mqtt-client doesnt support this evaluation kit. Is there any other way to fix this issue ?
Hi @Swarna :
Please check this repo mtb-example-ccm-mqtt-helloworld.
This is a code example connecting to AWS based on MQTT as well.
You can also create this project using Project Creator Tool directly.
Colin
Hi @Qi_Colin
We just want to do a mqtt data push to a gateway(Ubuntu based) with a static IP address. Without using any of the cloud infra like AWS or AZURE. Do you have any sample code for our chipset cy8ckit-064b0s2-4343w ?
Hi @Qi_Colin
This example uses Cloud Connectivity Manager kit, which we are not using . This wont be a good use case for us.
Hi @Swarna :
In this situation, no existent code example can meet your requirement.
I think you have two choices, one is add mqtt library and merge the application code from https://github.com/Infineon/mtb-example-wifi-mqtt-client to your project, and the other is create a ticket in Mycase system for custom help.
You can follow below to enter Mycase system.
Colin
Hi @Qi_Colin
Can you please guide us through as to how to add mqtt library to any project ? If we are going to opt for the first case ?
Hi @Swarna :
You can add any library you need in the Library Manager GUI of the MTB.
Detail information of Library Manager you can refer to the user manual.
Colin
