lesmalave
First solution authored 10 replies posted 5 questions asked
I'm having trouble getting the AnyCloud HTTPS Server demo to work with the PSoC6 Wifi-BT Kit. I have meticulously performed the steps to follow in the documentation without positive results.
I did the steps of the certificates also I formatted them ".... \ n \" do the steps of the certificates on the PC (I am using windows10).
I have reviewed the codes along with the documentation and I do not understand why it is not working for me.
Can you help me with this please ... I want to include this function in my next project.
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
May be I'm a little bit picky
I think that you need another backslash '\' after \"
So my secure_keys.h looked like
In case you have done that, I'm sorry for bothering you 😉
I also posted a CY8CKIT-062-WiFi-BT project at
https://www.electromaker.io/project/view/a-simple-sensor-server-using-cy8ckit-062-wifi-bt
moto
Aditi_B
500 replies posted 5 questions asked 250 replies posted
From your problem description, I assume that the program is getting downloaded successfully onto the kit and the bringup is also successful (as per the screenshot attached). The terminal also displays the URL but that URL isn't loading, right? Let me know if I've understood the problem correctly and provide any details that I've missed.
Aditi
MotooTanaka
Level 9
Level 9
moto
