We have refer AN221111-Creating a secure system and trying to build the secure image(dfu) and our user application(App1) for signed.
But this document and PDL3.1.2 example code is dual core CM0+ and CM4, ModusToolbox seems not support the Cortex M0+ core.
How should I import and design the dual core source to Modus run on CM4 and build out the hex?
Thanks for your help:)
BR,
Wayne
- mcu & psoc: psoc 6
Hi WaLo_3890256,
There are dual CPU example projects for ModusToolbox and you can check them out here -
However, there is no official support for secure_image application in ModusToolbox.
Thanks and Regards,
Rakshith M B
Rakshith M B
Hi WaLo_3890256,
Thanks and Regards,
Rakshith M B
Rakshith M B
