I don't have a MiniProg3 on hand right now, but I do have a PSoC5 LP prototype kit, with the break-away KitProg section.
I broke off that part of the board and wired the 5 pin header over to my target board (Vtarg, Gnd, RESET, SWDCLK, and SWDIO).
When I plugged the board into my laptop, it enumerated as a HID device. Creator doesn't find it as a programmer.
Can this board be used like this for debugging and programming (in lieu of a MiniProg3)?
If so - how do I get it to install correctly?
Dan
PSoC 5LP
Please check the "Hardware ID" of the HID device by the device manager. Do you see a device look like followings? And also check if the STATUS LED (LED3) on the board is blinking.
This ID is used to bootload a firmware into the KitProg PSoC 5LP device. There are several possible reasons.
1) The RESET button is pressed when the break-away board is attached to your PC. The KitProg device is going to enter to the bootload mode.
2) The target board or the break-away board has a large capacitor between XRES and VSS. When the break-away board is inserted while the capacitor is discharged, the XRES signal is recognized as LOW when the power supplied to the break-away board.
Noriaki
Noriaki
