Dear all,
I have a quite interesting bug (?) in my projects..
It seems like the sprintf function is changing the first declared uint16 in its value, even it isn't used in the function at all!
Also when using the debugger, some variables couldn't be changed, during the next instruction the value is changed.
Does anyone of you know this behavior or even has a solution for it?
Thanks a lot in advance,
best regards,
Thomas
Bob_Marlowe
Level 10
Level 10
Are you talking about Designer or Creator? And which version?
Bob
I am using Creator 1, right now I can't use the Creator 2 because I don't have the 24MHz Crystal for the CY8CKIT-050 yet.
Hi Thomas,
Can you please tell more about what you are trying to do and how you are using sprintf() function.
It will be easier to narrow down on the actual problem if you will attach the project.
Bob_Marlowe
Level 10
Level 10
I think we ought to know which compiler you use, 'cause the libraries are different.
There is another issue with sprintf, which seemingly is not able to handle floats in PSoC5, it only returns "0.0000" regardless of the given value.
Bob
How about upload your project so people here can help. If you can re-create the same problem using of the the development kits would even better so people could duplicate the problem.
