- Email to a Friend
I need to transmit data from usb-to-spi-elite (rom) as a master to psoc5 cy8c5888lt-lp097 as a slave in spi protocol.
where can i find the address slave?
for exemple : i want to blink the blue led p2.1
what the data that i need to transmit?
thanks .
PSoC5 LP MCU
- Email to a Friend
or10000,
Normally SPI doesn't use slave addresses. If you have multiple slaves on the same SPI CLK and Data lines you use different CSs (Chip Selects).
If you want to control the Blue LED on the CY8CKIT-059 board, it is easy. You control it directly. There are example programs to do just that.
If you start a new project, you can pick the "CE195352_PSoC_5LP_Blinking_LED" example project.
- Email to a Friend
or10000,
