Hello all,
I am writing a code where i am receiving data serially, this data is nothing but count and frequency. I am giving this data to counter.
I am giving count to counter with instruction Counter_1_WriteCounter(step)
and required frequency using instruction Clock_1_SetDividerValue(div)
This program works fine if i am not taking serial input from UAR, when i use constant number then counter is working fine with given step count and frequency, but when i include serial input code. then Counter is not working.
i am giving this code below which works fine without serial input
#include <device.h>
//#define LCD_NUM_COLUMNS (16u)
int main()
char8 arr[17]={'A',2,0,'B',1,'B',9,0,0,9,'D','F','F','F','F','F','F'};
//char8 ch=0;
uint8 i=0;
uint32 div=0,step=0,dir=0;
ControlReg_1_Write(0);
Counter_1_Init();
//LCD_Char_1_Start();
CyGlobalIntEnable; /* Enable all interrupts by the processor. */
i=16;
while(arr!='D')
if(arr!='D')
i--;
if(arr=='D')
uint32 n=1;
while(arr[i-1]!='B')
i--;
div = (div+(arr*n));
n=n*10;
if(div==14397)
CyPins_SetPin(Pin_2_0);
i--;
if(arr=='B')
i--;
dir=arr;
i--;
if(arr=='B')
uint32 n=1;
while(arr[i-1]!='A')
i--;
step = (step+(arr*n));
n=n*10;
if(step==1504000)
CyPins_ClearPin(Pin_2_0);
Counter_1_Stop();
Counter_1_WriteCounter(step);
ControlReg_1_Write(1);
Clock_1_Stop();
switch(div)
case 9009:
Clock_1_SetSource(CYCLK_SRC_SEL_IMO);
break;
case 36036:
Clock_1_SetSource(CYCLK_SRC_SEL_SYNC_DIG);
break;
case 3000:
break;
case 18005:
break;
case 14397:
break;
Clock_1_Start();
Clock_1_SetDividerValue(div);
Counter_1_Enable();
while(1)
Now the code that doesn't work when i include serial input.
#include <device.h>
int main()
char8 arr[17];
char8 ch=0;
uint8 i=0,buff_size=0,dir=0;
uint32 div=0,step=0;
Counter_1_Start();
UART_1_Start(); //Enable UART
/*-----------Receive data from UART and store it in array------------*/
UART_1_ClearRxBuffer(); //Clears the memory array of all received data
buff_size=UART_1_GetRxBufferSize(); //read the buffer size
while(buff_size!=17) //wait until buffer size is not equal to 17
while(i!=17) //stores the data in array upto termination character
ch=UART_1_GetChar(); //Returns the next byte of received data
if(ch<0x41)
ch=(ch-0x30);
arr=ch;
i++;
/*-----------------Data received and stored in array------------------*/
CyGlobalIntDisable;
UART_1_Stop();
i=16; //point to last array location
while(arr!='D')
if(arr!='D') //Decrement array until it points to 'D'
i--;
if(arr=='D')
uint32 n=1;
while(arr[i-1]!='B') //Extact the clock divider value form array
i--;
n=n*10;
i--;
if(arr=='B') //Extract the direction from the array
i--;
dir=arr;
i--;
if(arr=='B') //Extract the step value from array
uint32 n=1;
i--;
n=n*10;
/*----------Program to start counter and output the result to pin according to source----*/
Counter_1_Stop();
Clock_1_Stop();
switch(div)
case 9009:
break;
case 36036:
break;
case 3000:
break;
case 18005:
break;
case 14397:
break;
Clock_1_Start();
Counter_1_Enable();
while(1)
Anuja
PSoC 5 Device Programming
PSoC 5LP
With brief look looking at your code,
I think following code may be a problem
while(buff_size!=17) { //wait until buffer size is not equal to 17
while(i!=17) { //stores the data in array upto termination character
if(ch<0x41) {
ch=(ch-0x30);
arr=ch;
i++;
I'd rather write
UART_1_ClearRxBuffer() ; // Clear Receive buffer (I'd like to clear it before starting UART_1)
UART_1_Start() ; // Enable UART
buff_size = UART_1_GetRxBufferSize() ; // read the buffer size
while(buff_size < 17) { // buff_size could be bigger, please do not forget set buffer size of UART_1 to 17 or larger
buff_size = UART_1_GetRexBufferSize() ;
while(i < 17) {
ch = UART_1_GetChar() ;
if (ch < 0x41) {
ch = (ch -0x30) ;
arr = ch ;
i++ ;
// NOTE: Here, may be you need to print and check if arr[] contains the data you are expecting.
// something like
// #include <stdio.h>
// char str[32] ;
// for (i = 0 ; i < 17 ; i++ ) {
// sprintf(str, "%02X ", arr) ;
// UART_1_PutString(str) ;
// UART_1_PutString("\n") ;
moto
