resistors and capacitors
 hi to all,
              do we have resistors and capacitors in creator 2.0 for psoc 3.if they are in creator from where can we access and their firmware.
thanks
PRP
ETRO_SSN583
Level 9
Level 9
250 likes received 100 sign-ins 5 likes given
R and C elements in PSOC 3 only exist as annotated/schematic components, are
not physical components.
That being said take a look at this - http://www.cypress.com/?app=forum&id=2233&rID=63395
Additionally depends on what you are using R & C for, trying to create a filter, there is a DFB
block on the chip to do filtering. You could always create a sampled data  R or C via using a
mux as sampled data switch for R, with external C.
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
Regards, Dana.
ETRO_SSN583
Level 9
Level 9
Small correction, this -
Should be this -
You could always create a sampled data R using a mux as
sampled data switch for R, with external C. Its impractical
do do so with stray chip C due to values being so low.
Regards, Dana.
 so we have to use these externally only
