Dear All:
There is a I2C mater and several slaves with the same address so I need a mux to determine which slave device i want to control. And i use analog mux in the CY8CKIT-059 kit to implement my purpose.
p1[2] is SDAT source signal from master
p3[1] is connected to SDAT0 of slave device_0
p3[4] is connected to SDAT1 of slave device_1
as attached p1 shows.
and then I found it didn't work. So i took a measurement using scop as attached p2 shows.
channl4(green color) is clock from master
ch1(yellow) is measured by p1[2]
ch2(blue) is measured by p3[1] .
ch1 and ch2 should get the same signal when using analog mux as their connection bridge, but they don't.
how do i solve the issue?
Thank you.
by the way, all of my pins' type setting is "analog", drive mode is "high impedance analog".
ispn:39618:1:0
l1:314:1:0
PSOC5LPMCU
Ronny,
Take a look at this link:
Two-I2C-slaves-with-the-same-address
