Sep 20, 2017
08:28 AM
Sep 20, 2017
08:28 AM
I've a question.
In PSoC5 if I set in the pin configuration -> Reset -> Power-On Reset -> Pulled Up, does it means that the pin is pulled up if a reset occurs (for example for a watchdog or if I force a sw reset ....) or it is pulled up Always in every condition also at Power On ?
Thanks and regards
Labels
PSoC 5 Architecture
PSoC 5LP
08:42 AM
Sep 20, 2017
08:42 AM
The pins are originally in Hi-z mode when the chip is powered. This lasts until the configuration of the pins is loaded into the registers as part of the boot process. For a PSoC5 you can specify a different mode for this time span when required. When the boot process is finished the pin configuration is always what you specified for the pin component.
Bob
