shil_1288831
25 sign-ins 25 replies posted 10 sign-ins
I'm using CY8C5888AXI-LP096.
I'm trying to perform a non-blocking write operation to the EEPROM, but in the current state I'm getting a lot of delay in the system because of that.
I've added a file with the basic procedures, it won't compile but it will give the basic idea.
What I'm doing is calling every 5ms to appNVM_cyclicWrite() Its check if the EEPROM is ready and if it is, its extract data from a FIFO and write it to the EEPROM.
Am I doing it right? And is there another way to check the EEPROM state? (Without the checking of the temperature)
Thank you.
odissey1
Level 9
Level 9
user_384...,
I believe that writing to EEPROM is blocking, taking some ~20ms.
Way back I posted EEPROM saving component, check if any useful code there for your app
myEEPROM: component to save/recall application settings in EEPROM between power offs
You should also consider overrides limit of EEPROM (~1E+5) if data are saved every 20ms. There are Cypress kits with FRAM, which may work better for this type of application:
http://www.cypress.com/documentation/development-kitsboards/cy8ckit-044-psoc-4-m-series-pioneer-kit
/odissey1
odissey1
Level 9
Level 9
user_384...,
/odissey1
