Hello everyone
I'm trying to upload a code to CY8c5668AXI-LP010 and I get an error:
what could be the problem? I checked the connections of the mini prog and the board are connected in the required way.
thanks
From the image you have in your text, I understand you are using PSoC Creator.
From the [debug] menu of PSoC Creator, select [Select target and program...].
If you only see MiniProg4, Try pressing [Port Acquire].
If the target PSoC is displayed normally, please press [Connect].
If the above operation does not display the target PSoC device and only MiniProg is displayed, please compare the version of MiniProg4 with the above image.
