matrix programming CY8CMBR3110
Hi!
I want to program CY8CMBR3110 with the Arduino IDE or similar.
The 128-position EZclick-generated programming matrix:  Ex: ... .0x78u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x00u, 0x7u, 0x7Fu, 0x7Fu, 0x7Fu, 0x80u, 0x80u ....  I want to know who the recorder is for each array position above, since I want to program for low power consumption like look-for-proximity
ShanmathiN_06
100 replies posted 50 replies posted 25 replies posted
Hi!
Please refer to the MBR3 CapSense Design Guide (Section 5.2) at the following link:
http://www.cypress.com/file/127221/download
You can configure the MBR3 using host APIs.
The 128 bytes .iic files generated from Ez-click can be used.
The 128 bytes of configuration data are defined in the registers TRM at the following link:
Shanmathi
ShanmathiN_06
Hi!
Shanmathi
